-   Porsche 914 & 914-6 Technical Forum (http://forums.pelicanparts.com/porsche-914-914-6-technical-forum/)
-   -   Removing a stripped CV joint bolt (http://forums.pelicanparts.com/porsche-914-914-6-technical-forum/113675-removing-stripped-cv-joint-bolt.html)
iansale 06-05-2003 05:01 PM
I’m in the process of removing my engine. Thanks to the great technical article on Pelican, everything was going great. Then, I got to a CV joint bolt (one of those 8mm triple-square head jobbies) that had been completely stripped by the previous owner… just about perfectly smooth.
Assuming that he stripped it coming out, I can’t even imagine why he wouldn't have purchased a new bolt or how he managed to tighten it.
At any rate, what’s the best way to get the booger out? Thanks for any advice.
jamcleod 06-05-2003 05:12 PM
vice grips
sammyg2 06-05-2003 07:14 PM
Yep, either vice grips or a dremel. You can cut the head off and then remove the rest of the bolt after the CV joint is out of the way.
Vice grips are easier if it isn't killer tight.
iansale 06-05-2003 07:30 PM
Hmm... I tried vice grips, but it didn't seem like I had clearance to get a good bite. I'll try again tomorrow, I guess.
Pritchard 06-05-2003 07:32 PM
If your vice grips are older, ie. doesn't have sharp teeth, use a file and sharpen the teeth. I had to remove all my CV bolts using vice grips. Good luck, not much fun.
Pritchard
Zeke 06-05-2003 09:12 PM
Vice Grips. If they aren't good and new, buy some new ones. They're very handy. Use your old ones for nasty jobs like holding something whill heating it with a torch.
unclerichy 06-05-2003 10:01 PM
Took mine out with a dremel tool. Cut the head off and the rest came out with my fingers.
korijo 06-05-2003 10:41 PM
Step 1:
Make sure you're using the correct 12 pointed key, and not a Hex/allen/6 sided POS... DONT ask how I know.
Step 2:
Pound a small spare 10mm (IIRC) socket, preferablly a 12 pt., on the cv bolt head.
Rachet off.
bpick84 06-06-2003 06:50 AM
Needle nose vise grips work even better. I replaced all of mine with socket head screws (same strength) and now I can use a standard metric allen head socket. I know the "Porsche Gods" will get me for destroying their design, but it does make them easier to remove and torque.
PCA7GGR 06-06-2003 07:14 AM
air chisel
iansale 06-06-2003 05:18 PM
Never managed to make the vice grips work. But, I borrowed a very small stilson wrench, and it came right out.
