How much is too much!
What can I safely (using 92 octane) bump the ignition timing to? I have a 2.0L with 8:1 compression and a (.430 lift 270*) Web Cam.
THE NIGHT TIME IS THE RIGHT TIME
***AGENT 009, JAMES BONDO***
Old 10-30-1999, 12:56 PM
There is not just a set number I could tell you. What kind of distributor are you running (009, vac. advance)?
Start with the stock advance setting. Drive for a day or two keeping an ear out for pinging, and watch the eng temp. Advance the timing and repeat drive until you find the setting that works best for you.
Old 11-01-1999, 03:58 AM
I have a 009.
Old 11-01-1999, 08:18 AM
