-   Porsche 914 & 914-6 Technical Forum (http://forums.pelicanparts.com/porsche-914-914-6-technical-forum/)
-   -   Anyone repair a 1.8 Auxiliary air regulator (http://forums.pelicanparts.com/porsche-914-914-6-technical-forum/1140369-anyone-repair-1-8-auxiliary-air-regulator.html)
Fredie 05-21-2023 03:24 PM
Just wondering if anyone has found a way to repair the AAR on a 1.8.
There is a thread and video of the 2.0 and 1.7. And some outfit in California rebuilds them and sells them for a bunch.
It cannot be that difficult. What am I missing? There are other cars with similar displacement that use these. It’s just a slightly different Bosch part number
Regards,
Dave at Pelican Parts 05-21-2023 07:41 PM
The 1.8 AAR (unless you're talking very early 1.8, which uses what looks like the 1.7 one!) is a disk valve (disk with a hole in it) that is rotated by a bimetallic strip. If yours is truly broken, you can try opening it all up and cleaning it/checking if anything is disconnected/unsticking it.
--DD
Fredie 05-22-2023 08:22 AM
Thanks Dave.
I removed it from the car blew it out with low pressure air after flooding it with brake cleaner. I then moved the disc gently back and forth. Next I put it in the freezer and it opened up fully. Then I let it warm up to room temp. Next I heated it up for it to close. And this is the way it looks cooling again to room temp.
This seem correct? I have no baseline http://forums.pelicanparts.com/uploa...1684768820.jpg
Thank you!
Dave at Pelican Parts 05-22-2023 09:25 PM
If it opens and it closes, it is at least close!
--DD
Fredie 05-24-2023 06:02 PM
Thanks! Works well again. Hopefully for another 48 years.
Regards
