-   Porsche 914 & 914-6 Technical Forum (http://forums.pelicanparts.com/porsche-914-914-6-technical-forum/)
-   -   Front trunk (http://forums.pelicanparts.com/porsche-914-914-6-technical-forum/1141832-front-trunk.html)
slammin 06-17-2023 08:09 AM
Front trunk
Does anyone know how to get a 914 front hood open? Can’t seem to make the lever pop it up. It did a year ago it has been sitting outside now I can’t make it open .Had someone push down on the front hood when I pulled the lever pushing up and down nothing works. I need ideas how to get in there without destroying the front hood or any other parts of the car thanks for any info slammin out.
bdstone914 06-17-2023 04:59 PM
Have someone push down on the center of the trunk over the latch while you pull the handle.
If that does not work remove the bumper. There is a hole covered by a gromett that is used to trip the lock.
Use a small flat blade screw driver to trip the latch.
