-   Porsche 914 & 914-6 Technical Forum (http://forums.pelicanparts.com/porsche-914-914-6-technical-forum/)
-   -   Something I am missing about a spark plug change? (http://forums.pelicanparts.com/porsche-914-914-6-technical-forum/1144320-something-i-am-missing-about-spark-plug-change.html)
trader220 08-05-2023 12:50 PM
On a 1.7 I should NOT need to remove the tins to change the plugs right?
Seems to make sense to me. Yet none of the plug sockets seem to get a grip on the plug?
So long dumb question made shorter... what side plug socket should I be using?
djpateman 08-06-2023 07:04 AM
No.
13/16" is the usual spark plug socket size, but someone may have modified the heads and used a smaller plug.
Dave at Pelican Parts 08-06-2023 08:02 PM
Can you get a borescope in there for a look? You can get fairly inexpensive ones on Amazon now, or maybe at Harbor Freight.
You may need to put the socket on a 6" extension to get is all the way down on the plug, but it should still take a standard size socket.
--DD
930cabman 08-07-2023 11:00 AM
--DD
exactly, there will be no tin removal for changing spark plugs
