914 steering
Hi Is the steering on the 914-6 heavier than on the four cylinder cars?
Old 09-19-2023, 09:14 AM
The 9 Store
Shouldn’t be. It’s almost identical. Check alignment, tire pressure, etc.
All used parts sold as is.
Old 09-19-2023, 09:16 AM
dr914 ***********
no only with flares and wider wheels and tires does the steering feel heavier
Old 09-19-2023, 12:38 PM
914 steering
ok thanks for replies, i'll get the alignment checked, Again!!
Old 09-20-2023, 09:47 AM
What size tires are you running? pressure?
Old 09-21-2023, 02:35 PM
914 steering
Hi I'm running with 15"x6" Fuchs wheels fitted with 195/60 Falkens and Tyre pressures 26psi front 29psi rear and no bodywork mods.
Old 09-21-2023, 03:40 PM
Stock steering wheel or the smaller momo 350 mm type ? The smaller wheel is harder to turn
Old 09-23-2023, 07:12 PM
dr914 ***********
and if the front end is lowered!
Old 09-28-2023, 12:35 PM
Emo993's Avatar
I would add a few pounds fo tire pressure all around. Mark
1974, 914-6 GT Tribute
2007 Cayman S
1998 993 Carrera S, speed yellow (Yellow Bird) gone but not forgotten.
2017 Golf Sportwagon 4motion
Exclusive source for the 914 Umbrella and Service cover
Old 10-01-2023, 06:49 AM
From what I've heard, the steering on the 914-6 is generally considered to be a bit heavier compared to the four-cylinder models. The 914-6 had a larger and heavier engine, which could contribute to the difference in steering feel. However, it's always best to test drive both models if possible to get a better sense of the steering differences
Old 11-15-2023, 02:02 AM
