-   Porsche 914 & 914-6 Technical Forum (http://forums.pelicanparts.com/porsche-914-914-6-technical-forum/)
-   -   '74 914 2.0 AAR question (http://forums.pelicanparts.com/porsche-914-914-6-technical-forum/1149094-74-914-2-0-aar-question.html)
JMTaxter 11-10-2023 06:36 AM
Suspect AAR valve no good, so I have a question: Is the power source that heats the air on start up to activate the valve 6 volt or 12 volt or something else so I can test the valve on the bench? Thanks for your help.
dr914 11-10-2023 02:02 PM
12 volt but will also close if the valve itself is hot
JMTaxter 11-11-2023 06:19 AM
Where does the AAR lead typically connect? Is there any reason I can't get the 12V from the No. 15 side of the ignition coil?
Dave at Pelican Parts 11-12-2023 12:21 PM
The AAR coil connects to a wire in the ignition harness that goes back to the relay board and connects to the fuel pump power circuit. The wire gets +12V any time the fuel pump is running.
--DD
