Roll Bar Trim Holes
I am installing vinyl and trim on the roll bar of my 914. I need to know the location and diameter for the four holes for the clips that hold the trim located at the base of the roll bar. Thanks
Lauran
Old 12-27-2023, 04:09 PM
dr914 ***********
Have someone make you a template from an original car. Also if your car had side vinyl originally, if you look closely down the side there may be remnants of where the holes were filled
Old 12-28-2023, 07:48 AM
Can someone please send me a template and hole size for the clips for the roll bar trim at the base of the roll bar?
Old 12-29-2023, 05:11 PM
nothing to see here
My suggestion is to post this request on 914world along with your location; the odds are good there’s someone near you whose car you could look at and make a template from.
Old 01-03-2024, 02:19 PM
I clarify. I am looking for information on the holes for the trim at the base of the sail panel.
Old 01-08-2024, 01:55 PM
Control Group
Tobra's Avatar
Where are you? Good chance there is someone local to you that can help you out. I can post a photo with a ruler next to it or something for scale.
Old 01-09-2024, 05:04 PM
