replacing accelerator cable
When replacing the accelerator cable, are there any other parts (bushings, etc) that should be replaced as well?
Thanks, ~Eric |
I believe that I didn't replace anything else. It didn't seem necessary. Then again, I had recently been through the pedal cluster and some of the rest of the areas the throttle cable passes through.
As usual, check the parts while you have them apart and have easy access. Fix what's messed up. --DD |
| All times are GMT -8. The time now is 02:17 PM. |
