Go Back   Pelican Parts Forums > 1- Porsche Technical Forums > Porsche 914 & 914-6 Technical Forum
Rob914's Avatar
Send a message via AIM to Rob914
Subwoofer in a 914
I'd like to have a sub in my car, just a little one would be nice, has anyone done this, or does anyone know one that would fit somewhere
http://www.pelicanparts.com/gallery/Rob914/
76 914
Old 06-27-2003, 11:37 AM
skline's Avatar
I have seen several people use bass tubes in front of the passenger seat. I myself am going to make a box to fit in the area on the floor where I removed the foam thing under the front passenger floor board and I will be running one 8" facing the center of the car. This will still leave the passenger plenty of leg room and I wont have to worry about them sticking their foot through the woofer. I will post pictures when I get it done.
http://www.pelicanparts.com/gallery/skline
It's easier to get forgiveness than it is to get permission.
75 Slantnose V8
03 S-10 Extended cab stepside in Yellow
72 914 Parts car
Old 06-27-2003, 11:45 AM
tat2dphreak's Avatar
a box can also be build to go under the dash, pointing to the floor, on the pass. side... hidden!
an 8" or 10" would be about the biggest you could go...
'72, now with a living, breathing 2056...
Old 06-27-2003, 11:48 AM
Tonyakavw's Avatar
Send a message via ICQ to Tonyakavw Send a message via AIM to Tonyakavw
http://www.914club.com/bbs2/index.php?act=ST&f=2&t=1587&hl=subwoofer&
there's some good pictures there..
My installaton looks like this...
I built my own box and it uses a 6 inch sub. Certainly won't give you a ton of bass, but it sounds pretty decent.
-Tony
Tony
70 914 EJ25 - Body by Karmann, Engine by Fuji Heavy Industries
Old 06-27-2003, 11:49 AM
Rob914's Avatar
yeah thatd work but i kind of want to keep it hidden, pref under the pass side where that foam deal is
76 914
Old 06-27-2003, 11:55 AM
Tidybuoy's Avatar
Skline, That's the best idea I've heard. I'm gonna make one. It would be neat if you could use the orig foam as a mold for a new fiberglass speaker inclosure.
Vern
'06 Cayman S - Arctic Silver
'74 911 Coupe - Silber Metalic, PMO ITB, Electromotive Mgt
2016 BMW R Nine T - Motorcycle (the fun one)
2018 BMW G 310 R - Motorcycle (fun but too slow)
Old 06-27-2003, 12:07 PM
skline's Avatar
The way I am doing it is as follows, I am going to start with a 12" wide 3/8 particle board for the face and cut it to match the contour of the firewall which will take it down considerably, and then use another piece to go across the floor board which will be carpeted to match to floor where the passenger can put their feet. Then I will cut my hole for the woofer and mount it on the inside so it does not stick out from the box. I will take rubber sponge ribbing and attach it to the entire side that makes contact with the floor and firewall to seal it. I am using a free air woofer which will work well with or without ports. I should have enough air space inside the box to make it hit pretty good. The sound will all be inside the car. To anyone looking into the car they wont even be able to tell it is there or see it. I will let you all know how it comes out.
75 Slantnose V8
72 914 Parts car
Old 06-27-2003, 12:22 PM
Rob914's Avatar
my amp blew weeks ago so i bought a nice new top of the line 4 channel alpine amp to replace my 80s amp, i also got a capacitor to give it enough power, ive got last years top of the line alpine head unit and infiniti reference front and rear, YES, i went a little crazy on the stereo system, the great part is its all hidden, ive got the oroginal stereo in the dash the alpine hangs underneath, i cant wait until i get it all installed it will be crystal clear, now all i need is a little sub, ill post pics
76 914
Old 06-27-2003, 12:36 PM
JWest's Avatar
Here's one that was posted here long ago:
James
JWest Engineering
Old 06-27-2003, 12:37 PM
Rob914's Avatar
WOW, i like that one
76 914
Old 06-27-2003, 01:26 PM
JRust's Avatar
Here are some pics of mine. I used the foam pad there for a mold for my fiberglass & built of of that! Worked out great although for the 10" sub it has to be a little big. When I do another one I will just use a good 8" sub so it can sit closert to the stock foot pad!
Jamie Rust
73' 2.0
PacificNW914 club member
Old 06-27-2003, 02:27 PM
Biggy72's Avatar
I saw one mounted to the side of the center console once. I thought that looked really good.
Black 72 1.7 914
http://www.pelicanparts.com/gallery/Biggy72/
WSU Formula SAE
Drivetrain team leader/ Suspension team
http://www.mme.wsu.edu/~sae/
Old 06-27-2003, 04:23 PM
Worstmanassoc's Avatar
My car started life as a '73 1.7 with the storage bin instead of the Appearence Group guage console. I removed the storage bin and reproduced it in 3/4 inch birch plywood. I mounted and 8" sub in the side that faces the passengers feet. I covered it in that "monkey fur" stuff and it worked out great. I does not intrude into the car in any way and I even built a small "very small"storage area in the lover front of the box that can hold lighters, pens, etc and it doubles as a port for the sub. Many of todays subs are not real dependent on cabinet volume and this setup sounds great.
Old 06-27-2003, 04:25 PM
Biggy72's Avatar
any pics?
Black 72 1.7 914
WSU Formula SAE
Old 06-27-2003, 04:28 PM
iamchappy's Avatar
I like mine in the backpad firewall seat recess area
check the link audio install pics # Audio Install
914 6 Turbo twinplug 3.12
87 924S
Lexus SC400
Lexus LS400
Old 06-27-2003, 07:50 PM
iamchappy's Avatar
Heres a picture of it
87 924S
Lexus SC400
Lexus LS400
Old 06-27-2003, 07:54 PM
Joe Bob's Avatar
I put a bazooka tube in front of the passenger seat.....
See me for graphics. www.nbdgraphics.com 83 cab, backdated with 3.6 I want a Porsche fix until I die. 2012 Mercedes ML350, 1980 Suzuki GS 1000S
Old 06-27-2003, 08:13 PM
canna change law physics
red-beard's Avatar
Here's my dual subwoofer:
James
Red-beard for President, 2020
Old 06-27-2003, 11:06 PM
JRust's Avatar
Unfortunately RedBeard your dual sub would kick my 2.0 in no time flat. Thanks for reminding me of my inferiority in still driving a 4. I almost went the week without 6envy!
Jamie Rust
73' 2.0
Old 06-28-2003, 12:17 PM
M. Hendrix's Avatar
I love your plate!
M
I wish I had a dime for every penny I ever had.
http://www.914club.com/bbs2/uploads/blog-1136350347.jpg
Old 06-28-2003, 12:45 PM
