-   Porsche 914 & 914-6 Technical Forum (http://forums.pelicanparts.com/porsche-914-914-6-technical-forum/)
-   -   Failed Emissions Help (http://forums.pelicanparts.com/porsche-914-914-6-technical-forum/1167252-failed-emissions-help.html)
FrostyCVW9 09-20-2024 11:01 AM
I recently acquired a 1974 914 2.0 and just failed emissions. Idle HC's were 439 and the allowed max is 400. I feel like I'm close. Any help on adjusting the fuel mixture leaner would be much appreciated. I believe it's as simple as counting "clicks" on an adjustment screw in the lean direction, but I don't know where that magical screw is located or which direction is lean and which rich. Thanks!
Dave at Pelican Parts 09-20-2024 10:54 PM
Idle HC is adjusted with the knob on top of the ECU. I believe that left is lean, and right is rich.
Make sure your ignition system is in tip-top shape as well. I had ignition points that were not in great shape and it really threw my emissions out of whack!
--DD
jess p 09-21-2024 04:43 PM
Additionally, add a few pints of straight ethanol to your gas before you go to emissions. No more then 2 pints.
bowlsby 09-24-2024 07:22 AM
What state/jurisdiction tests a 1974 914 for emissions? I thought they were exempt everywhere by now.
FrostyCVW9 09-25-2024 06:23 AM
Thanks for the pointers, fellas! Good to have this information. After a bit more research into testing regulations, I found an exemption for classic cars, but it required me to drop the 914 from my conventional insurance and get “classic car insurance” which I got at Haggerty. Appreciate the comments. BTW, jurisdiction was Tucson, AZ. For no restrictions, cars have to be 1966 or earlier to have a full emissions exemption. Rural registrants also have exemptions.
dr914 09-28-2024 09:59 AM
maybe a leaking pressure sensor
mitchhy 10-03-2024 10:05 AM
To adjust the fuel mixture on your 1974 914 2.0, you’ll want to locate the fuel mixture adjustment screw, which is typically found on the fuel injection unit
azbanks 10-05-2024 03:27 PM
@FrostyCVW9
Welcome to the bird board from a fellow Arizonian. I am north of Phoenix.
Tobra 10-07-2024 03:20 PM
I have had an oil change bring my HC down
