jkeyzer's Avatar
looking for a dyno in san diego
I want to do some simple dyno runs with A/F meter in the San Diego area. Anyone know of a dyno shop and how much I can expect to pay?
I am guessing this is the most straightforward way to check my A/F ratio vs. RPM at part/full load.
Jeff Keyzer
72 914 w/2056 built by Mark DeBernardi @ Original Customs
Megasquirt with MSII upgrade
Old 06-26-2003, 06:51 PM
John Rogers's Avatar
I don't know if you'd need a dyno shop although there is one in El Cajon that my shop uses and one in Oceanside too. Which ever is closer for you but it sounds like you need several hours with an a/f meter and some tweeking to get things right. Good luck.
Old 06-26-2003, 09:17 PM
Andrew 4square's Avatar
Cool
Mech Tech in Escondido can probably do what you need as well...
-black where there is paint
-in need of a six fix
-Can't squeeze into that race seat anymore?--Call me for all your fitness needs
A-Train Fitness-(562)883-3025
Old 06-26-2003, 10:30 PM
Bleyseng's Avatar
Send a message via ICQ to Bleyseng
If you do go and check, your part load mix should be about 13.7 to 1. Don't let a dyno get set it to 14.7 to 1 which is for modern water cooled cars.
Read Brad Anders site pages as you can adjust the MPS to be spot on.
Geoff
76 914 2.0L Nepal Orange (2056 w/Djet FI, Raby Cam, 9to1 compression)
www.914Club.com
My Gallery Page
Old 06-26-2003, 10:32 PM
jkeyzer's Avatar
Do I need an LCR meter to adjust the stop screw accurately? Otherwise how do I know the armature is resting on the screw and not stressing the diaphram?
Also how much should I expect to pay for an hour of dyno time with the A/F meter?
Jeff Keyzer
Old 06-26-2003, 10:34 PM
Bleyseng's Avatar
You need a inductance meter like the Wavetek to measure the position of the "stop" screw as it sets the WOT mix. If you measure it carefully before disassembly you will get it close again. If you do adjust the MPS when at the dyno shop adjust only the inner screw not the outer screw to adjust the A/F at partload. Hold the posision of the outer screw with a screwdriver while adjusting the inner screw.
I still think something is messy with the mix but what
Geoff
www.914Club.com
My Gallery Page
Old 06-27-2003, 08:17 AM
Kenny Powell's Avatar
Hey Jeff, in response to your last question last I heard the going rate for Dyno time down here was $75 per hour more or less............probably more!
75' 2.0 w Ljet
"I like the way she doesn't move in the curve's... and then she let's go!"
Old 06-29-2003, 08:11 AM
Kenny's about right as to the cost of dyno time. I think that is what I payed when they did my race car and in addition the tech from the shop went too so that can be a added cost. You will need to make sure that the dyno guys can adjust a 914 FI system since those that can work on them well are getting rare? Good luck.
Old 06-29-2003, 11:04 AM
Bleyseng's Avatar
I always get the response-
"you can't adjust Djet"
Geoff
www.914Club.com
My Gallery Page
Old 06-29-2003, 11:57 AM
jkeyzer's Avatar
I can't buy time in half hour increments? =-]
I'd like to baseline things first before I make any changes. I have no idea what I'll find...
Jeff Keyzer
Old 06-30-2003, 11:04 PM
