Hardflex: that was the first thing I thought too... I also thought... oh great, now I'll have to get the "new" heads machined to allow them to fit the cylinders into the heads... but no... the inside diameter of the cylinder was less than 91mm(~90.4) so... they are 90mm... I assume they are either stock pistons, or the PO changed the pistons instead of just the rings
Re: 1.7 vs 2.0?
Ah shucks, I miss the dancin' bannana!
Here ya go, Ron. You can save it to your hard drive.
Alfred http://persweb.direct.ca/aschwenk/mueba.gif |
