-   Porsche 914 & 914-6 Technical Forum (http://forums.pelicanparts.com/porsche-914-914-6-technical-forum/)
-   -   Bus 2.0 engine????? (http://forums.pelicanparts.com/porsche-914-914-6-technical-forum/117643-bus-2-0-engine.html)
sasquatch 07-05-2003 01:19 PM
Bus 2.0 engine?????
My alignment mechanic has a complete VW bus engine sitting in the back of his truck, complete with injection and exhaust. He pulled it out of his daughters bus. He said it was smoking bad, and using alot of oil. So he just pulled it and put in a new one.
I am toying with the idea of buying it for upgrade parts for my 74 1.8. Would any of the 2.0 bus parts be worth anything to me? How about the good 2.0 crank and rods? He felt the heads were shot, but ???
Let me know if I should offer him anything for it.
Jay
AaronM 07-05-2003 04:20 PM
Actually, the whole dang engine is useful if it can be relatively easily cured.
Aaron
Dave at Pelican Parts 07-05-2003 07:04 PM
The heads are "worse" (i.e., less high-performance oriented) than any of the 914 heads. Ditto the pistons. Most of the rest is fine--particularly crank and rods.
--DD
jamcleod 07-05-2003 07:41 PM
a vanagon could be considered a bus. check for oval exhaust ports or square exhaust ports. 914's have oval. vanagons had 2 liters when air cooled.
sasquatch 07-05-2003 09:08 PM
Sounds good, I'll try to score it. What would it be worth used? Worn out, but running.
Jay
jamcleod 07-05-2003 09:37 PM
if it's a bus engine and running, it's probably L-jet :>) to put in a 914 you have to put in a new dipstick and if it's a vanagon, block off the oil filler. worn out would be a core motor $2-400 but that's a guess. could be an educational motor (learn by taking apart) but by your list of vehicles, i'd guess you're beyond that.
sasquatch 07-06-2003 04:29 PM
Way beyond the educational phase.
I am thinking about pulling it apart for parts. Usint the 2.0 crank and rods in my 1.8 with big bore cylinders and my stock injection.
All the parts I do not use, sell on ebay.
Jay
auh 07-06-2003 08:30 PM
hmmmm, a bus engine in a 914. My dad almost put a 914 engine in a bus. That's gotta mean somewhere along the lines parts are interchangable, right? Good luck!
Adam
