Question on Turn Signal Dash Lights.
Figured it out! Thank you…
Having an issue with my turn signal indicator light, works whenever it wants.
Please share, thx |
I had previously checked out the fuses and as much wiring and found nothing obviously wrong. A new relay solved my problems. If you are just having problems with one light it may be a ground issue with that one bulb.
