-   Porsche 914 & 914-6 Technical Forum (http://forums.pelicanparts.com/porsche-914-914-6-technical-forum/)
-   -   performance upgrade (http://forums.pelicanparts.com/porsche-914-914-6-technical-forum/118576-performance-upgrade.html)
auh 07-11-2003 01:40 PM
performance upgrade
What is the best performance upgrade you have ever done to your 914?
Adam
red-beard 07-11-2003 01:47 PM
Purchasing a Factory 6....
James
Rouser 07-11-2003 01:59 PM
Installing 4 Dunlop SP Sport A2's in P205/60-15's.
Whatever power your car currently makes, you might as well get it to the ground in a controlled fashion.
http://www.pelicanparts.com/ultimate...WavingFlag.gif
Bleyseng 07-11-2003 02:56 PM
Dyno tuning the Djet FI to get the right A/F mix and lots more hp.
Geoff
sammyg2 07-11-2003 03:21 PM
9 psi boost :)
mikeferg75 07-11-2003 03:46 PM
Making sure my blinker fluid was full :rolleyes:
Jim Smolka 07-11-2003 04:29 PM
Installing a flat 6 cyl motor :D
Bob Bischoff 07-11-2003 04:46 PM
Water pump and a 350 chevy.
:cool: :cool:
madd_dogg_914 07-11-2003 05:50 PM
TAKING A DRIVING CLASS
By far the best thing performance wise was to take a drivers ed class. It was a group class at Laguna Seca, it was expensive, but worth every penny and more. Put a bunch of power under your right foot, and if you don't know how to handle it then you may have been better off with the car before. You will be surprised what you can get these little cars to do . . . Ask Brad Roberts, he'll tell you to do the same thing prolly. After you can drive it, then the best upgrade would be, just like Jim said, a flat 6!
-Chris
mikester 07-11-2003 08:51 PM
Best performance upgrade: Bright Chrome Yellow Paint job.
Because everybody knows, "yellow cars go faster"
madd_dogg_914 07-11-2003 11:54 PM
Not just yellow cars go faster. YPAF!!!
Yellow PORSCHES are faster
-Chris
toman 07-12-2003 03:12 AM
I'm with the rest of these guys; yellow paint for sure. Oh, that and rack spacers. :D
Kenny Powell 07-12-2003 08:03 AM
I would say chucking the points........and going with some type of electronic ignition! Also the high volume oil pump are 2 good upgrades.
Silvio914 07-16-2003 03:10 PM
Green pine tree air freshener....:D
sammyg2 07-16-2003 04:02 PM
Oh, you mean you were serious? OK, I'll try to knock off the jokes for a second.
A 914/4 is not going to be fast in a drag race unless you spend cubic dollars on a large displacement four or unless you install a six or eight (or turbo).
There are things you can do to make it run smoother, an electronic ignition was already mentioned and I agree completely. Making sure the engine is tuned properly is very important. Unfortunately there's not much you can do to make more power without major changes to the engine's internals.
BUT...... what do 914s do best? Handle. IMO the best thing you can do to increase the performance is to improve the already good handling.
Very high quilaity tires, anti-sway bars, stiffer torsion bars or springs, and good shocks all make big differences in the performance.
As you are doing all that you will quickly discover that the car will outperform the driver. That's where the driving instruction comes in.
There is no way i would have ever really learned the limits of one of my cars if I had never participated in an AX or DE.
Plus it is so much fun it makes me grin like a fool ,even more than usual.
Jake Raby 07-16-2003 05:18 PM
Adding a "2316cc Annihilator" from my own line up....LOL
Jake Raby
Raby's Aircooled Technology
www.aircooledtechnology.com
M. Hendrix 07-16-2003 07:42 PM
I am for the sway bars, and good tires.
Seats, man you need seats if you are planning on turning (RED-BEARD Mustang spanker!) or you should yank the belt really hard before you get 2 fast and furious.
M
neal c. 07-16-2003 08:40 PM
Don't forget the brakes!
Sooner or later you gotta stop.
Neal
sean_V8_914 07-17-2003 09:09 PM
best bang for the buck was a driving class. I never knew what a difference a day makes...or what suspension loading was. option B: buy a book and find a safe place to try stuff. dammit, they built a Walmart in MY SPOT.
red-beard 07-17-2003 09:13 PM
Still remember that? Wow, that was a good day! :D
James
