valve adjustment
I'm trying to adjust my valves. I've never done this before, but I refuse to pay to have it done or it defeats the point of a 914. Anyway, my problem exists because I replaced the flywheel when replacing the clutch and may or may not have put it back in the same place it came out, thus I cannot trust the marking for the TDC. When I check TDC in the fan housing / rotor and compare it with the flywheel they are not matching. So, I'm not sure how to know where I am in adjusting the valves. I can make a mark for TDC, but the 180 degree mark is what is throwing me. Is there any way to exactly tell when a valve is open or closed? And is it open or closed that I adjust them?
Thanks in advance!!
Nate
914 2.0 Silver Ghost (A ghost because the paintjob at this point is so faint)
Old 07-12-2003, 07:58 PM
jamcleod's Avatar
Send a message via AIM to jamcleod
use the timing marks on the fan and the distributor rotor pointing to the mark on the dizzy housing
73 914 restoration project
73 914 2.0 CIS #80
74 914 1.8L L-jet
83 911SC
Old 07-12-2003, 08:24 PM
