-   Porsche 914 & 914-6 Technical Forum (http://forums.pelicanparts.com/porsche-914-914-6-technical-forum/)
-   -   What a Mess... (http://forums.pelicanparts.com/porsche-914-914-6-technical-forum/121204-what-mess.html)
neal c. 07-29-2003 10:23 PM
What a Mess...
Last weekend I found time to take the engine out. Problem was a massive oil leak and a "bad" noise...
I dropped the tranny first then the engine. Not a difficult task. I tried to label all the electrical connections and hoses until I got impatient and just disconnected things and figured I would remember later anyway. I am sure there will be a lot of questions later to the list
:rolleyes:
When I removed the cooling sheet metal I found a mess of old oil, black gunk and pine (?) needles. http://forums.pelicanparts.com/uploa...1059542081.jpg
Hmmm, would that have an effect on cooling and engine life? I guess, it did.http://forums.pelicanparts.com/uploa...1059542204.jpg
Judging by the build-up of gooey crap inside the fly wheel, the mainseal was not just leaking since yesterday..http://forums.pelicanparts.com/uploa...1059542372.jpg
On the bright side, the heads look good. No cracks there.
Next weekend I'll split the case. At this point, I am prepared for anything.
Neal
WOODPIE 07-29-2003 11:05 PM
Wow! You got all the "good" out of that piston, didn't you?
skline 07-29-2003 11:26 PM
You either have big fat fingers, or that is a 1.7 liter stock piston. Looks to be a little worn. I would replace it.
Dave at Pelican Parts 07-30-2003 08:51 AM
I dunno, a little bit of bead blasting and a quick coat of silver spray-paint ("Tijuana rebuild"), and I bet you can get a lot of $$ for them on e-bay.... ;)
--DD
jamcleod 07-30-2003 01:02 PM
but DD, you can only get alot of $ for it on ebay if you're
parker@***********.com :D
Ron Meier 07-30-2003 02:58 PM
got hot - galled the skirts of the alum piston - yep, ya got a<P><h2>WINNER</h2><p>Next!
neal c. 07-31-2003 10:39 PM
Well, this is a 2L piston and my fingers are NOT fat. :D
Big maybe and strong, but not fat. Not, not, not fat...
Neal
