Va914's Avatar
Fuel pump relay
Fuel pump stopped last night ??????????
After some looking around and checking things, I think I know where the problem is...Where does the + signal to activate the fuel pump relay come from? I have verified all other wires and connections.
If I jumper across the relay connections I can make the fuel pump run.
I think it's the signal from the ECU???
Does the same signal to activate the fuel pump go to another location? Anything else on this signal?
Cheers
Kerry
Kerry (Back on the road, sort of)
914-6 in the Werks
Old 08-04-2003, 05:31 PM
Tidybuoy's Avatar
I may not be able to answer your question but here goes: If you have a 1.8, the fuel pump only runs when the engine is running. As the air flap moves, it triggers the fuel pump to run. You can check by turning on the ignition, removing the black cap on the air flow meter & moving the meter needle.
Unfortunately, I can't answer your question if you have D-Jet 1.7 or 2.0
Vern
Vern
'06 Cayman S - Arctic Silver, "R" Springs & Struts, Spyder 19" Wheels, 82mm Plenum & Throttle Body.
'74 911 Coupe - Silber Metalic, PMO ITB, Electromotive Mgt
'16 BMW R Nine T (the fun one) & '17 BMW G310R
Old 08-04-2003, 06:13 PM
Va914's Avatar
Thanks..
I keep forgetting to indicate this in my Q's
I have a 1974 with a 2.0L D-Jet..
Also, I have power to both sides of the fwd most fuse on the engine relay board. When does the aft most fuse get power? With the key on the aft one has no pwr?
914-6 in the Werks
Old 08-04-2003, 06:18 PM
Administrator
Send a message via AIM to Dave at Pelican Parts Send a message via Yahoo to Dave at Pelican Parts
On a D-jet car, the fuel pump power comes from the fuel pump relay on the relay board. The fuel pump relay is triggered by the ECU supply or removing a ground from one of the "switching" contacts on the relay. The relay always has power going to its "input", regardless if the car is running or not. So if you jumper the relay the pump should always run.
Relay board diagram:
http://www.pelicanparts.com/914/parts/Electrical/914_electric_73E.jpg
Note that pin 86 of the fuel pump relay goes to the four-pin connector which the ECU wiring harness plugs into. Pin 85 of the fuel pump relay is hooked up to the output of the FI power relay, so it will have +12V any time the ECU is getting power. Pin 87 is the output from the relay and goes to the pump, and pin 30 is the input to the relay. It is powered by the rear-most fuse, and should have power all the time.
Sounds like you need to check the red wire hooked up to pin #14 of the front 14-pin connector on the board.
BTW, the fuel pump power supply also feeds the Auxiliary Air Regulator. Note it hooks over to pin #12 of the 12-pin connector on the right-rear of the relay board.
--DD
Old 08-05-2003, 09:29 AM
Va914's Avatar
Thanks Dave..
I now have power to both fuses on the relay board. BUT I still have no power to the fuel pump.
If I force the fuel pump relay to make contact the pump runs. It seems like the signal form the FI relay is not getting to the pump relay????
Any more thoughts..
Thanks again
914-6 in the Werks
Old 08-08-2003, 12:49 PM
bowlsby's Avatar
Ummm...bad relay?
Old 08-08-2003, 01:30 PM
Administrator
Like I said on the "other board", unplug the four-pin connector and ground the left-front pin on it. The pump should run when the key is on. If not, then unplug the relay and check the relay socket pin #85 to see if it has +12V.
Then plug the connector back in again (turn the key off first), and poke a probe from your multimeter down to the back side of that same pin. Have someone turn the key from off to on. For about 1.5 seconds, you should see that pin get grounded by the ECU.
Tim's 914 Fan Page has a long text article about D-jet fuel pump troubleshooting. http://www.914fan.net/fuelpump.html
Brad Anders has a flowchart for troubleshooting D-jet fuel pump problems. http://members.rennlist.com/pbanders/FPChecklist.htm
--DD
Old 08-08-2003, 01:40 PM
Va914's Avatar
Thanks I'll give that a shot his weekend.
I have swaped in 3 relays and no change so I ruled out the relay. The relays are not new but worked before swapped out.
Thanks again guys
Kerry
914-6 in the Werks
Old 08-08-2003, 03:18 PM
hardflex's Avatar
FWIW, I had fits trying to track down the same type of fuel problem, and it turned out to be a bad connection across the fuse on the relay board. Double check it to be sure. Mine showed voltage but there wasn't enough punch to make the pump go.
72 914 2056: 74 9146 2.2: 76 914 2.0
Old 08-08-2003, 08:48 PM
10 914's and counting
ctc911ctc's Avatar
Links are dead
Dave,
Could you please refresh the links on the attachments mentioned in this article?
Thank you!
Respectfully,
Cary Conrad
Boston MA
Old 08-11-2018, 08:25 PM
Administrator
Archived version of the 914 Fan Page article: https://web.archive.org/web/20000929210032fw_/http://www.914fan.net:80/fuelpump.html
Supposedly this page has Brad Anders' fuel pump troubleshooting slides, but I can't see them. https://members.rennlist.com/pbanders/FPChecklist_frame.htm
Not sure what the issue is with that. Searching through archive.org produces basically the same results...
--DD
Old 08-12-2018, 05:15 PM
