EGR line -- bend or remove?
Hi all
i just bought a new bursch muffler (from PP!) for my 75 2.0, but find that my EGR line (the aluminum-looking pipe) doesn't line up with the new muffler. rather, the EGR line is over near the passenger-rear wheel, where it attached to my old exhaust.
has anyone had luck "bending" this pipe into place? it doesn't seem to want to go anywhere, but wonder if i may coax it into place with the help of a torch.
or, could i just block the damn thing off? how about removing the whole EGR system? i know this wouldn't pass the visual inspection for the smog test -- this is hypothetial only.... although i technically won't ever need another smog test before it becomes exempt.
any advice appreciated.
i'm your child's T/A. scared yet?
Old 08-13-2003, 11:29 AM
Just had to go through smog, hopefully for the last time her in CA, on my 75. Here is one approach.....
I went down to Home Depot and purchased a 3 foot flexible gas line with fittings intended for hooking your gas drier to the natural gas line.
Each end came with adapter fittings to convert larger line down to the 3/8 dimension of the flexible hose.
Using these, or other fittings, weld a 3/8" male fitting to the exhaust prior to the Cat or attach to the Cat EGR pipe.
Cut off the EGR pipe where it meets the engine wall and weld/brase another 3/8" male fitting to the small mounting plate there.
Then use the flexible gas line to connect the two points.
I also purschased some 3/8" end caps so I could remove the new "EGR pipe" after smog and cap off both ends of the run.
I passed visual and smog and the flexible line is off and filed away in case CA changes is 30 year rollilng smog exemption and I have to get smogged again
- Dave
Old 08-13-2003, 12:41 PM
