Temp Sensors
76 914 2.0
Does the 76 914 have the second temp sensor located adjacent of cyl 3? According to the Haynes manual there is one sensor near the throttle bottle and a second near #3's plug. I ask because I have no connection for it and my fuel pump is not running. Everything else has been checked, relay, fuses, etc(the pump will run when wired directly but I understand that this is not safe.) |
i think it should have a cylinder head temp sensor (CHT) like the 73-74 D-jet
Yes, it should be there. But it will not keep the pump from running.
Brad Anders has some flowcharts for troubleshooting the fuel pump on his website. http://members.rennlist.com/pbanders . --DD |
If you have no TS2 as you describe...dont count on your engine running anytime soon....at least if its got the D-Jet FI.
| All times are GMT -8. The time now is 07:00 PM. |
