-   Porsche 914 & 914-6 Technical Forum (http://forums.pelicanparts.com/porsche-914-914-6-technical-forum/)
-   -   Next problem (http://forums.pelicanparts.com/porsche-914-914-6-technical-forum/123905-next-problem.html)
auh 08-18-2003 03:41 PM
Next problem
When ever I hit the brake pedal or use my turn signals, I lose all my gauges and my generator light turns on.
When I got home, I checked my fuses and one of them was burnt out.
Unfortunatly I don't know what it goes to.
The fuse box cover has the letter K next to it and a box with 6 vertical lines and one horizantal line.
What is this fuse for and is it the cause of my problem?
Adam
red-beard 08-18-2003 04:11 PM
Ground issue.
red-beard 08-18-2003 04:16 PM
Probably in one of the bulbs in the back end of the car, or the wiring is messed up in one of the tail lights.
James
red-beard 08-18-2003 04:18 PM
One other thought - It might be a bulb in the rear which has too high a wattage rating. This combined with a cheated fuse could do what you are describing.
philinjax 08-18-2003 05:11 PM
Replace the fuse, it should be the 4th from the right side, S9.
philinjax
Conrad W Peden 08-18-2003 05:28 PM
Had same problem. It was one of the wires for the taillights.
After I replaced the bulb holder I was damned if I could get all the wires to fit back in the tail light bucket. Guess I pinched one.
PS. If your losing your speedo too it might be somethin else!? ;)
Tidybuoy 08-19-2003 02:19 PM
I get the exact same problem every once in a while. Replace the 4th fuse from the right (even if it dosen't look blown). This should solve the problem.
