Starting the serious wrenching
Picked up all the new parts on Friday and cleaned a spot on the work bench.
The shop washed the case halves but I still spent a couple hours cleaning the mating surfaces.
Then I cleaned up the old crank bearing with 80 grit sandpaper,.....NOT!
I got the cam and crank in place without problems, but I sure took my time and was very carefull.
Last picture before the case was closed and torked. Everything seems to work, crank moves smooth.
Neal
Old 08-23-2003, 10:36 PM
Andyrew's Avatar
Great pics! Dont see too many type 4 botom ends, mostly piston stuff... Looks like you have a project on your hands!!
Good luck!
Old 08-23-2003, 11:35 PM
jamcleod's Avatar
Send a message via AIM to jamcleod
more....more.....
73 914 restoration project
73 914 2.0 CIS #80
74 914 1.8L L-jet
83 911SC
Old 08-24-2003, 04:58 PM
[QUOTE]Originally posted by Andyrew
[B]Great pics! Dont see too many type 4 botom ends, mostly piston stuff... Looks like you have a project on your hands!!
That is the first time I have seen and fondeled a cam or crank in real life. I changed a head on my camper bus 15 years ago and that is as far as I have torn into these things.
Next step is to clean the pistons and cylinders and stick them on.
Neal
Old 08-24-2003, 08:00 PM
