Biggy72's Avatar
gas tank problems
in the middle of pullin an all nighter last night I found some rust on my gas tank, and on further inspection I have no idea how it wasn't leaking. I hit it with a wire brush and it fell through.... I know I can fix the hole back up, well holes, but what do I use to coat the inside?
Black 72 1.7 914
http://www.pelicanparts.com/gallery/Biggy72/
WSU Formula SAE
Drivetrain team leader/ Suspension team
http://www.mme.wsu.edu/~sae/
Old 08-31-2003, 11:46 AM
Never have used it but POR-15 has a fuel tank repair kit, http://www.por15.com/product.asp?productid=316 or fuel tank sealer http://www.por15.com/product.asp?productid=163. But it might be better to invest the 50 bucks into pulling the tank and taking it to a repair shop.
Old 08-31-2003, 03:37 PM
Biggy72's Avatar
already have the tank out and some of it pulled apart. I'm gonna weld up the holes. That's not a big deal. I was cleanin it out a little bit ago and had it catch on fire and singe the hairs off my right hand.... I'll let it sit for awhile before i go back to workin on it.
Black 72 1.7 914
WSU Formula SAE
Old 08-31-2003, 05:37 PM
I got to admit you got balls to weld on that gas tank. I suppose it's safe now if it already caught on fire and burned off the fumes. I'd run a some car exhaust into it anyway and fill it with some inert gas (but not from a car running too rich of course), or some CO2 (MIG welder or fire extinguisher). Good luck and be safe.
Old 08-31-2003, 05:49 PM
Biggy72's Avatar
I'm gonna fill it with water a couple times and make sure it's all washed out first.
Black 72 1.7 914
WSU Formula SAE
Old 08-31-2003, 05:50 PM
I think Craig (Camp 914) Laughlin in Portland has an unrusted one (or more) if you decide yours is too far gone.
Old 08-31-2003, 09:03 PM
Biggy72's Avatar
well I'm goin to a swap meet down there I think he's gonna be at next weekend, so I'll know by then whether mine's worth saving or not, and I guess it depends on his price.
Black 72 1.7 914
WSU Formula SAE
Old 09-01-2003, 01:27 AM
The Por 15 tank restoration kit works as advertised. I did mine last year with good results but the job is a bit messy. If you have the opportunity to buy a good used tank, this might be a better/quicker option.
You'll spend about $50 on the restoration kit and two days between cleaning, etching, application and cure times.
John
'73 914
(Renegade V8 conversion)
Old 09-01-2003, 01:58 AM
Fuel tank availble Sept. 6th SUNSET Porsche swap meet. $50.00
CCL
Craig C. Laughlin CAMP 914
Helping to bring your 914 into the 21st century.
http://www.camp914.com
Old 09-01-2003, 09:02 AM
Biggy72's Avatar
if it's as nice as said I'd like it. Just got done welding it all up, and it's ok, but if the coating stuff's gonna be that expensive I might as well buy yours.
Black 72 1.7 914
WSU Formula SAE
Old 09-01-2003, 01:38 PM
I will bring it with me to the swap meet. You can decide when you see it, holds fuel and it doe's not have rust spots.
CCL
Old 09-01-2003, 02:00 PM
