LinkBack | Thread Tools | Rate Thread |
What Do I Have Going On Now ??
Cary 77 Carrera RS w/3.2 #59 73 914S 2.0 AG 73 914 1.7 Driver ( daily driver, under complete rustoration ) 74 914 2.0, 71 914 Tub, 74 914 2.0 Tub + 73 914 donor |
Hey there Cary,
I had the same problem with my 1.7. I changed the TPS. It helped a little but not completely. Then I did the CHT. Again, it helped a little but... I pulled the dizzy, cleaned & checked the FI points... then noticed a slight wobble in the dizzy shaft. Put it back in and sometimes it ran strong & sometimes it got the sputter back. I still had the points & condensor set up so I went to the Pertronics electronic ignition. That seemed to take care of the sputtering at 3k. It may have been just the points but it also could'a been a combo of changing it all. bruce ps. I have your tape of the autocross. Can I send it to the Main St. address?
Sit'n here Hav'n a beer. Punkin's gone (sniff) Gotta mow the Lawn... |
Yes, that would be great. How much do I owe you ?
I've been reading the posts you had. Sounds about the same thing. I think the more we drive it. The more things are loosening up. I know the TPS is shot. Had a real bad flat spot at 2800. I'm pulling it off this am to take a look at it. I ordered a new one last night. CHT is withing the #'s. The dizzy is my next project. Sounds like the FI trigger points might be it. Dwell is right 49.5. But how do you get the b***h out. The VA is right over the clamp nut. Out to tinker this am. But I have to reset the ride height on the Carrera for our biggest AX, Monday. At one of the car dealerships on one of Missoula main drags. Lots of folks. On the 1.7 we'll get her figured out. TTYL.
To get to the nut so's ya can extract the dizzy you'll need to loosen the adjustment nut and turn the VA outta the way then it's visible. Here's a pic from Pelican showing the adustment nut
http://www.pelicanparts.com/techarticles/914_timing/914_timing_pic2_big.JPG. It's a hard pic to read. Mark the placement of the dizzy before loosening and twisting it outta the way so's you can get it back in the right position. That way it'll at least start & you can re-time it. Don't worry 'bout the cost of shipping. I think it's only a couple bucks & the tape is a used one from work! ![]() Good luck bruce
Thanks for the shipping.
I'm waiting for the TPS. I'm pretty certain thats it. My drivabilty problems are strictly related to the pressure on the throttle. The car will roll up the 5k as long as I don't mash down on the throttle. After about 1/3 throttle the engine goes to mush. Should be here by the weekend.
73 Yellow 2.0 86 Toyota 4X4 |
Administrator
The auto-URL recognizer included the period he put at the end of the sentence. Just remove that final dot and it should work.
To avoid this problem in the future, put a space in between URLs and any punctuation. E.g., " http://www.pelicanparts.com/techarticles/914_timing/914_timing_pic2_big.JPG ." --DD
Pelican Parts 914 Tech Support A few pics of my car: http://www.pelicanparts.com/gallery/Dave_Darling |
Way to go Dave! thanks
bruce
Thread Tools | |
Rate This Thread | |
