Missing rear caliper part
I could use some suggestions on what to do with my rear calipers. While rebuilding them I noticed the adjustment screw gear (the little gear adjusted from the rear of the caliper) is missing on one caliper. Someone apparently lost it during a past rebuild. Does anybody know of something I can substitute for this part, or can I adjust it by turning the piston gear teeth with a small screwdriver? That's how I got it apart, but I'm afraid without the gear the pad adjustment will not stay fixed. Thanks for any suggestions...
Old 09-02-2003, 05:20 PM
Administrator
Send a message via AIM to Dave at Pelican Parts Send a message via Yahoo to Dave at Pelican Parts
The adjuster simply slides out. You can use the one you have and switch it from caliper to caliper. I don't think they're available separately, so you may have to find yourself a used or rebuilt (or whatever) caliper to raid for that part....
Or maybe you can make one from a gear and a big set-screw?
--DD
Old 09-03-2003, 08:02 AM
Thanks Dave. Moving it from one side to the other should work. Maybe I'll run across a cheap rear caliper to scavenge the part someday (better yet - maybe 911 brakes all the way around).
Old 09-03-2003, 06:05 PM
*********** supposedly has them. er..I did just place an order w/pelican
'74 914 V8
'70 914
Old 09-03-2003, 07:49 PM
grind weld build
sean_V8_914's Avatar
I bought some from Auto atlanta for I think $5 ea. arrived in 6 days
good luck. Ive been told I got lucky
flesh heals, memories last forever!
73 Orange, CS #601
73 Rayco V8 glug, glug
69 911 w/82 turbo look on 275 35 18s (for sale)
Trek 6500+
Sean M!
Old 09-03-2003, 11:07 PM
You must have gotton lucky - they're listed for $25 now. Actually two mistakes were made - charged you only $5 AND they shipped it in a timely manner. Someone must have gotton fired for that screw-up. I can get a complete rear caliper off eBay for $20.
Old 09-04-2003, 07:36 AM
grind weld build
I sold a set of rebuilt and painted rears on ebay for $200. Go for it
73 Orange, CS #601
Trek 6500+
Sean M!
Old 09-04-2003, 09:20 AM
