Dbelleperc's Avatar
Ajustable Rear Springs
Can anyone give me some more info on the "coil over" suspension for the rear of the 914, so I can set the ride height from 4x4 or all the way to the ground. Does only Koni make it like the picture? Or is it something you can also fit on the Boge and Bilstein shocks. TIA.
70' Porsche 914
73' Porsche 914
03' Mini Cooper S
03' Volkswagen Passat GLX B5.5 4-Motion
Benjamin Miles Keaton (ben, lj) - RIP June 2nd, 2005
Old 09-03-2003, 11:58 PM
John Rogers's Avatar
I have a setup like that on my race car but the shocks are Koni yellow sport shocks (little stiffer). As far as I know that is about the only off the shelf setup although there are several race shops that sell other brands and they tend to be more expensive. When we put the set on my 914 we set the spring perches in the middle and marked them and the nut with a dab of white paint. Then while the car was level we adjusted the rear height down so it was what we wanted. Unfortunately these setups are not cheap!!!
Old 09-04-2003, 05:28 AM
drew365's Avatar
I have adjustable perches on Bilsteins. I bought the setup from Paragon. Remember that as you adjust the height your also changing the corner balance of the car. We adjust the height on scales with me in the driver seat and leave it optimized for equal weight distribution.
Old 09-04-2003, 07:31 AM
Stay away from my Member
campbellcj's Avatar
I have a similar setup that I got from Coleman Racing Products, along with Hypercoil springs. Actually I haven't installed them yet, though...gotta to that soon. I'm running Bilstein's.
The key advantage is much finer adjustability than the stock style "stepped" perches. Also most of these setups use a 2.5"x10" coil so you have an almost unlimited selection of springs available; whereas normal 914 stock-type springs only come in a handful of rates (I think).
Chris C.
1973 914 "R" (914-6) | track toy
2009 911 Turbo 6-speed (997.1TT) | street weapon
2001 F150 Supercrew 4x4 | tow vehicle
Old 09-04-2003, 09:24 PM
chrisreale's Avatar
I have this set up on my Koni Yellows also. Im a bit pissed , because I have the adjustable perch basically bottomed out. Others I know have a older det up and theirs is in the middle.
1973 914 2.0 PCA Member GGRwww.pelicanparts.com/gallery/chrisreale/
www.914club.com
Old 09-04-2003, 11:28 PM
Chris,
I would also like to go with adjustable perches and have been wondering how to get there without trial and error. Your problem was touched on in the Club914 forum where Brad pointed out to someone that they would need an 8" instead of a 10" spring to work on Koni Reds (which I have). I know you have Yellows, but I assume the principle is the same.
Do you recall the length of your springs? What is the spring rate? How is the ride? Do you need a spring compressor to install them?
Thanks,
Mike
Old 09-05-2003, 05:08 AM
Never left, but not right
Zeke's Avatar
Me too, because I'm using stock length springs. The short springs (10" BTW) are not available in the ranges that I would prefer. You really have to go with the smaller diameter springs and perches to get the best setup. It comes as a package with the shocks. I'll be using Koni Sports from Paragon. I don't think Pelican has these, at least they didn't when I asked. It's OK, I buy enough from Pelican. (Almost everything)
Old 09-05-2003, 06:52 AM
chrisreale's Avatar
Not sure about the length. They are 200# and the ride is hard! But this is for AX, and comfort on the street has been sacrificed. In the last pic, it looks like mine are indeed ten inches long. I did not need a compressor.
Here is a thread on my install
http://www.914club.com/bbs2/index.php?act=ST&f=5&t=3926&
www.914club.com
Old 09-05-2003, 01:19 PM
drew365's Avatar
Chris; from the pic it looks to me like your Hypercoils are 12" springs. It should have said on the cardboard cylinder they came in.
Old 09-05-2003, 02:41 PM
chrisreale's Avatar
Of course, ya tell me two days after I junk the carboard cylinders! Either way, with the 22mm torsion bars, 200# springs, 22mm saw on mid, it is not that comfy on the streets, but it is very neutral handeling. A proper alignment and corner balance will make it stick even more
www.914club.com
Old 09-05-2003, 03:33 PM
