-   Porsche 914 & 914-6 Technical Forum (http://forums.pelicanparts.com/porsche-914-914-6-technical-forum/)
-   -   5 Lug Rear conversion question (http://forums.pelicanparts.com/porsche-914-914-6-technical-forum/126289-5-lug-rear-conversion-question.html)
skline 09-06-2003 02:50 PM
If I install the drilled 5 lug hubs, can I just buy the 914/6 rear brake rotors and install them on it? Or do I have to drill the rotors also?
mikester 09-06-2003 03:49 PM
that is what I was told to do when I was looking into it. You have to have a little bit on the inside of the caliper removed though, they are little bigger that the 4 lug disc.
skline 09-06-2003 04:02 PM
The reason I ask, there is a guy on Ebay selling a set of new rear 914/6 rotors for $200.00 starting bid. Pelican sells them for 65.00 each. I can just get a set of those and be done with it.
Zeke 09-06-2003 04:34 PM
Just buy the Pelican ones. You don't have to do much if anything to install them. They go right onto the drilled hubs. Some find it necessary to trim off a tad of the overall diameter in a brake lathe because of what Mike said. You could probably do it with a belt sander right on the car.
mike95125 09-08-2003 05:25 PM
I used drilled out rotors.
Dave at Pelican Parts 09-09-2003 10:22 AM
Probably cheaper to use 914-6 ones. Unless you have the right drill bits for your drill press, and don't count your time as worth anything...
--DD
joe buckle 09-10-2003 12:54 AM
Scott, its a pain in the ass....just give me those big FUCH's and i'll make sure they get a good home.....trust me....:eek:
Scooter311 09-10-2003 05:49 AM
Hawdy, folks
I bought 914-6 rotors from the guys who drilled my hubs - they fit poifectly. Just bolt on and go, I didn't have to do anything to the calipers.
Buy them at Pelican, the prices are very competitve.
Cheers,
Jeff
mikester 09-10-2003 06:22 AM
Yeah Scott, I'm with Joe - but I think you'd rather see them on my car.
skline 09-10-2003 06:29 AM
They wont fit on either of your cars. With 245X50's on them I assure you, they will rub. And Joe, I know that you have a complete set of 16's already.
