ruddyboys's Avatar
Front calipers
I ordered a pair of front calipers, found out when they were delivered they are both driver side, the place i bought them from said there is no differece and can be interchangeable. Is this true? Also does someone have a source for the spreader spring, the old ones lost the rivet and are very brittle. Thanx
74 LE "Bumblebee"
03 Jetta Wagon
Old 09-08-2003, 03:58 AM
John Rogers's Avatar
Well the place you bought them from is sort of right, except that the vent screw will be on the bottom if you put the driver's side caliper on the right. I'd recommend trading it for the correct one so you don't have to try bleeding the caliper off the car and then putting it on. As far as I know the springs are NLA so I'd try fixing it with a rivet which is what I did a couple of years ago and it works okay. Good luck
Old 09-08-2003, 06:38 AM
elwood-914's Avatar
Ruddyboys,
I bought my speader springs from Pelican, it's not in the on line catalog but I talked to one of the sales people and they found it no problem.
1973 green 1.7
1973 Orange 2.0
1989 Ford F-150
Old 09-08-2003, 06:43 AM
ruddyboys's Avatar
John, These Calipers have the two bleeders are there a difference. Also how can you tell the difference visually between left and right.
74 LE "Bumblebee"
03 Jetta Wagon
Old 09-08-2003, 07:07 AM
tat2dphreak's Avatar
if they have a top and bottom bleeder... then there is no difference...
'72, now with a living, breathing 2056...
Old 09-08-2003, 09:04 AM
He's correct, if there are two bleeders, no difference at all. Good luck
Old 09-08-2003, 09:27 AM
Tidybuoy's Avatar
I recently rebuild my calipers (with two bleeders). I couldn't tell a difference between the two.
Vern
'06 Cayman S - Arctic Silver, "R" Springs & Struts, Spyder 19" Wheels, 82mm Plenum & Throttle Body.
'74 911 Coupe - Silber Metalic, PMO ITB, Electromotive Mgt
'16 BMW R Nine T (the fun one) & '17 BMW G310R
Old 09-08-2003, 05:09 PM
Ron Meier's Avatar
The early calipers had two bleeders and should be interchangeable. The later calipers have one bleeder and are not interchangeable since the bleed screw would be in the wrong place or so my experience says.
I know nuthin'
"Inventor - Blue Flame 914 Seat Heater"
"Yellow Rusty Cars Are Faster"
_____________________________
'70 2.5 (I'll never finish it - Somewhere over the rainbow.....,)
'73 2.0 (Just Not The Same)
'74 2.0 (Heartless & Lungless)
Old 09-08-2003, 07:54 PM
sammyg2's Avatar
OK, possible dumb question here:
the little piston angled contact thingy (technical term) is supposed to be at a certain angle to level, right?
If you take a caliper and put it on the other side, you would have to make an adjustment to that angle, basically re-setting it, right? please don't flame me too hard if I'm all messed up, for some reason I can't picture it in my head right now.
Old 09-09-2003, 01:42 PM
You align the notched-out side of the piston against the direction of rotation. Depending on how the caliper mounts, basically the edges of the notch line up to the center of the axle. I think this is what you're referring to anyway.
Old 09-09-2003, 02:22 PM
I brought my beat-up spreaders to Foreign Auto Parts and they matched it....with what I don't know but it looked the same and fit.
Ed
'74 914 V8
'70 914
Old 09-10-2003, 06:46 PM
