415pb's Avatar
Powdercoating...Pics inside
Hi everyone...Well, I thought I would give a stab at powdercoating, so I purchased all the necessary equipment and after a couple practice runs, this system works great and it's easy too. Thought I would share the experience:
This came out great..It's a red but looks orange in the pics...
1974 914 2.0 D-Jet
2004 BMW R1150RT-P
Old 09-08-2003, 09:52 AM
Used the el-cheapo Harbor Freight system? What did you use for an oven?
Old 09-08-2003, 10:06 AM
415pb's Avatar
I'm using the Caswells el-cheapo system. But, I guess there all the same. I just picked up a toaster oven, so I really am limited right now. It's working out pretty good though. I plan on buying an electrical "CHEAP" oven, hopefully soon.
914GT, where do you buy your powders? and does it really make a difference?
Thanks,
Rod
1974 914 2.0 D-Jet
2004 BMW R1150RT-P
Old 09-08-2003, 10:56 AM
ruddyboys's Avatar
Does it powdercoat a burrito?
74 LE "Bumblebee"
03 Jetta Wagon
Old 09-08-2003, 11:10 AM
415pb's Avatar
I guess it would........
1974 914 2.0 D-Jet
2004 BMW R1150RT-P
Old 09-08-2003, 11:12 AM
I've bought powders from Eastwood. You can powdercoat anything able to handle the oven temp (400F or so) and able to conduct electricity. A burrito probably does not fit that description, although I had one once that did.
By the way - I bought a cheap toaster oven from Costco which works great. It's funny telling my wife I have to go to the garage to check on something in the oven. Got a pair of calipers in there. I did all my windshield and rollbar trim with a heat gun. That works for parts that don't fit in the oven and will heat up quick with a gun. I was going to try a couple 1000W halogens I have sometime to see how they would work out.
Old 09-08-2003, 11:52 AM
Good info. How do you plan to heat the larger engine sheet metal? Does anyone know how the shops do large pieces? With an oven or with heat lamps? There was a thread on the 914Club forum and people discussed using heat lamps with reflectors to direct the heat.
Mike
Old 09-09-2003, 09:10 AM
415pb's Avatar
914GT
How did the heat gun work, was the powder cured evenly with it? The curing lights are a bit expensive and I have been debating on whether to buy one or not. Still haven't located an oven yet, I have been looking everywhere. I'm to cheap to buy a brand new one. The toaster oven works fine for now, but I'll be doing the larger sheet metal soon. I just picked up some powder from Eastwood and I will give it a try.
1974 914 2.0 D-Jet
2004 BMW R1150RT-P
Old 09-09-2003, 10:36 AM
The heat gun works, I think it chips a little easier especially with thicker parts that take longer to heat up - probably not curing long enough or hot enough. But thin stuff like trim you can get really hot with the gun and it works fine.
The commercial shops use big walk-in ovens or IR quartz lamps. For a home shop I'd think cheap 500-1000 W quartz halogen security lights would work. Most of the energy is converted to heat which is what you want.
I bought a new toaster oven for $39, then saw one at the local thrifty store for five bucks. Wonder if they'd take my new one back after it's smelling like powdercoat and yellow & black plastic baked on? I'd tell them I'm just a lousy cook...
Old 09-09-2003, 11:21 AM
415pb's Avatar
Thanks for the info...I guess I'll go pick up a heat gun and give that a try. I have a heat lamp also, I'll go ahead and experiment with that too.
Thanks again,
Rod
1974 914 2.0 D-Jet
2004 BMW R1150RT-P
Old 09-09-2003, 03:42 PM
You'll just have to try it. The bigger the wattage (1500+) the better. How it works all depends on the 'thermal mass' of the part and how well you can get localized temps up to 400 deg. or so. Maybe put a heat lamp on the back side and the heat gun on the other. Don't worry about the heat gun blowing off the powder, it sticks pretty good.
Old 09-09-2003, 05:10 PM
415pb's Avatar
How about orange peel, have you ran into this and how do you take care of it. Some of the stuff I've done has a slight orange peel. They say to sand it then buff it, but it does not seem to work...
Rod
1974 914 2.0 D-Jet
2004 BMW R1150RT-P
Old 09-09-2003, 05:33 PM
I've got some orange peel. On the parts I've done it's not been a problem. I have not tried sanding and buffing, don't see why that would not work. You'd want to sand with a hard block with maybe 1500 wet, then buff with a wool pad and compound. You could try sanding and recoating with powder too. Seems the oven gives less orange peel than the heat gun, no doubt due to the melted powder better able to flow out smoother.
Old 09-09-2003, 06:23 PM
415pb's Avatar
914GT:
Thanks for all the information
Rod
1974 914 2.0 D-Jet
2004 BMW R1150RT-P
Old 09-10-2003, 05:06 AM
415pb's Avatar
914GT:
I'm starting to powdercoat all my tin and intake runners. I was just wondering if I could powdercoat with a regular powder or do I have to use the high temp powder?
Thanks,
Rod
1974 914 2.0 D-Jet
2004 BMW R1150RT-P
Old 09-19-2003, 08:09 PM
Rod, the regular powder should be ok. I don't think these parts get real hot, but maybe somebody with more experience with working on these motors can comment if these part get anywhere close to 400 deg. If they do you better go with the high temp powder.
Old 09-20-2003, 04:58 PM
Never left, but not right
Zeke's Avatar
Why not get a household electric oven from a remodel or applicance store that deivers and takes away the old? Many times these things work OK. You know, you be stylin' if you got a double oven built in model. You could have 2 batches going at once. Hide the electric bill fom your wife.
Old 09-20-2003, 08:40 PM
Administrator
Send a message via AIM to Dave at Pelican Parts Send a message via Yahoo to Dave at Pelican Parts
The heads will get close, but if they get to 400F you have real problems. The intake pipes should be cooled by the air going through them (to some extent) and the fuel being squirted into the area. They are also insulated from the heads by those plastic "phenolic block" spacers/gaskets.
Regular is prolly OK.
--DD
Old 09-21-2003, 02:46 PM
415pb's Avatar
Thanks guys, I'll give it a try........
Rod
1974 914 2.0 D-Jet
2004 BMW R1150RT-P
Old 09-21-2003, 03:19 PM
415pb's Avatar
I finally powdercoated my intake runners....
1974 914 2.0 D-Jet
2004 BMW R1150RT-P
Old 11-03-2003, 02:39 PM
