-   Porsche 914 & 914-6 Technical Forum (http://forums.pelicanparts.com/porsche-914-914-6-technical-forum/)
-   -   Anybody ever try machining rear hubs? (http://forums.pelicanparts.com/porsche-914-914-6-technical-forum/126577-anybody-ever-try-machining-rear-hubs.html)
cruiksdr 09-08-2003 06:54 PM
More specifically, for the five lug conversion, has anyone ever tried machining the splines on the 914 stub axle to fit the 911 rear hub?
I've got the complete rear running gear (hubs, rotors and calipers) from a 911 that I'd like to use. I like the hub because it is nice and heavy duty, but of course, the stub axle won't work. Seems like it would be possible to have the 914 machined to mate with the 911 -- or am I completely insane??
Thanks!
Daniel
PS: thanks to all those who helped me out over the weekend regarding bearing removal. What I learded... There's so much history here, I need to remember to search on the question first. Lots of wisdome and experience out there :D
Ron Meier 09-08-2003 08:44 PM
The splines would be more correctly "hobbed" not machined.
So, have a machinist cut you some axle shafts and have each end splined for the cv joint you want to use.
Or use the 911 hubs in the 914 trailing arm. Believe the bearing ID is the same and the axle a little shorter so you have to have a 1/2" spacer machined for the inboard cv joint.
Clay Perrine 09-09-2003 05:45 AM
Why go to all that trouble? Get 944 turbo stub axles and CV joints. Make usre that you get the ones from the 944 with the aluminum trailing arm. The stub axles fit an early 911 (i.e. 914/6) hub, and the CV joint is splined the same as a 914/4 axle. It's a true bolt together, and you get a bigger, heavier duty outboard CV joint. If you want a bigger inboard joint too, find the transmission drive flanges from a 75 911 with a 915 transmission. They will bolt into the 914 transmission, and they have the same size and 6 bolt pattern as the 944 turbo CV joint. And don't forget the gasked for the 911 transmission flange when assembling.
sammyg2 09-09-2003 09:46 AM
Clay, now that is some good information. Gonna file that one away for future reference. Thanks.
M. Hendrix 09-09-2003 05:11 PM
Rockin' Clay!
That is good to know, you can but a whole 944 Turbo for less than the price of stub axles.
M
