auh auh is offline
auh's Avatar
Send a message via AIM to auh
Carbs ?
I think my carbs are running rich.
When I hit my gas pedal the engine spudders like its being flooded and i get a raw gas smell.
What do you guys think?
If it is too rich, how do I lean them out?
Adam
1974 914 1.8 Sold...
1984 944 my baby...more of a pain in the @$$ than takin' it with a cucumber, but I still love it. THE CAR YOU PERVS!!!!!!!!!!!!
1990 Nissan 240sx fastback aka Japanese 944
Old 09-10-2003, 06:08 PM
tat2dphreak's Avatar
there are adjustments on the side... get a synchronizer tool...
'72, now with a living, breathing 2056...
Old 09-10-2003, 07:06 PM
chrisreale's Avatar
Put Fuel Injection in it
1973 914 2.0 PCA Member GGRwww.pelicanparts.com/gallery/chrisreale/
www.914club.com
Old 09-10-2003, 09:37 PM
auh auh is offline
auh's Avatar
Haha, thats a pain, but a premium. I think I'll stick to my webers.
Old 09-11-2003, 01:47 AM
yes put on the f.i. if it doesn't crap out on you between seattle and portland you're good to go. what size carbs are you running? could you be more specific than "..sputters.."? is this while sitting or nailing it while rolling? what rpm? do you get popping back thru the carbs? how do the plugs look? get the webber book from c.b. read it!! go thru the setup proceedure then read the trouble shooting guide. it's very detailed and specific. under 3000rpm or so it's all idle circuit so lets start with your idle jet size. there is a screw head near the top of the barrel of each carb body, to the side of the fuel inlet pull one and look. try setting each a/f screw at 2 1/2 turns off of bottom to start. other than a plugged idle jet/ circuit (a 10 mintute fix), my 40's on a 2.0 with a triad linkage, cb rotary fuel pump, and a real t-4 fuel filter i've had no problems.
kevin
Old 09-11-2003, 05:14 AM
pbanders's Avatar
Send a message via Yahoo to pbanders
If you give all the particluars on your carb setup, Jake Raby can probably diagnose what's wrong in 1 minute.
Old 09-11-2003, 06:55 AM
I'm installing one of those A/F mixture gauges (CB Performance), not sure how accurate they are, but it should let me know if the A/F mixture is in the ballpark. Sure don't want to burn up those new valves!
This is probably OVERKILL x 4, but I'm concidering putting an O2 sensor in each of the exhaust outlets just before the muffler. I saw a slick A/F mixture bar graph set-up on a Triumph GT6 site that you can make very cheap (my favorite word). This guy used one on each down-pipe of his exhaust (2 sensors and bar graphs), and it kept track of the individual carbs. By using 4 of these set-ups plus my CBP gauge, I could theoretically tune each cylinder individually, and keep track of how they are running (lean/rich) at any rpm or load. I'll see if I can fine the guy's website.
Here it is:
http://www.buckeyetriumphs.org/technical/Carbs/AFMonitor/AFMonitor.htm
"Whether you think you can, or think you can't, you're probably right" - Henry Ford
'73 914
'75 914
Old 09-11-2003, 10:54 AM
DDS DDS is offline
More information please.....
Synch them, set the idle, get the idle mixture dialed in, re-set the idle, and then make sure the accelerator pumps are functioning correctly.
For a quick check see if all pump jets are squirting identically when you kick the accelerator, and only when you kick the accelerator.
Consider getting CB performances Weber car book, it specializes in porsche and VW 4-bangers, explains how they work, has a decent trouble shooting guide, gives some quick and dirty tricks to try.
I'm getting the hang of my old DCNFs - the learning curve is short (but frustrating).
Good luck.
-- Dave
'73 914, 2056 GT/SC done!
'69 Lotus Europa S2 - under resto.
pics at
http://www.syer.net
Old 09-11-2003, 06:10 PM
