-   Porsche 914 & 914-6 Technical Forum (http://forums.pelicanparts.com/porsche-914-914-6-technical-forum/)
-   -   What exactly is the difference between an 1800cc VW Bus engine and a 1.8L 914 Engine? (http://forums.pelicanparts.com/porsche-914-914-6-technical-forum/127574-what-exactly-difference-between-1800cc-vw-bus-engine-1-8l-914-engine.html)
Alfred1 09-15-2003 04:03 PM
Are the heads different. How about the cooling tin?
Thanks.
Bleyseng 09-15-2003 04:21 PM
Its the same tin. The pistons are different and cam.
tat2dphreak 09-15-2003 05:05 PM
:confused:
I thought it was just the cam and the compression ratio... the bus had 7.3:1 vs. 8.6:1 on the 914 and *some* bus' came with carbs.. europe models as well as '74-'75 models with auto. trans. used L-Jetronic f.i., otherwise dual carbs....
the heads are the same... and I *thought* the pistons were the same(same dish) how were the pistons different?
http://tunacan.net/t4/reference/case.htm
Alfred1 09-15-2003 05:22 PM
I just found some info in Tom Wilson's book:
"Basically, the 1.7 - and - 1.8 liter 914 engines are very similar to their VW counterparts, differing only in air filter placement, sheet metal and exhaust valve material."
jamcleod 09-15-2003 07:37 PM
compression ratio on 1.8L 914 is still only like 7.6:1, so it's not much more than a bus. i bet if you check the part numbers of cam and pistons and probably heads too, the numbers for a bus and a 914 are the same. now there will be a difference maybe in the oil fill and the dipstick, at least there is with a vanagon, right off the top i don't know a bus 1.8.
Eat-um-up 09-15-2003 10:43 PM
Well not only does it have a differnt cam and crank. the block is also differnt. The 914 block is drilled out for the dip stick. adapting a bus case for a 914 is really easy though. the heads are also different as well. Not horribly. they have differnt compressions.
James
Alfred1 09-15-2003 10:59 PM
So, is Tom Wilson wrong? I don't know, that's why I'm askin'.
Eat-um-up 09-15-2003 11:01 PM
No i dont belive Tom Wilson is. There is just that other differance in the case. I know this becouse i but a bus engine in my 914 once.
