fuse question
I think the PO put in the wrong fuses. First to make sure I have the numbering right is fuse 1 closest to the driver door. 2nd If thats the case I have a white fuse in fuse 6 parking light right and a blue fuse in fuse 5 parking light left. What is the corect color fuse for each fuse terminal.
If you click on "tech specs" in the 914 section of the links on the left-hand side of the main Pelican page, you'll find the following link:
http://www.pelicanparts.com/914/technical_specs/914_electrical_fuses.htm --DD |
| All times are GMT -8. The time now is 07:54 AM. |
