did my fuel pump go out?
ok... started my '74 2.0 w/carbs Sunday night to time it and (try to) synch the carbs...
As usual, as soon as I turn the ignition on, I hear the clik-clik-clik of the facet fuel pump. It started... Everything was fine.
Next day I go to start, and no clik-clik, and no start.
Would the fuel pump fuse and relay be in the same spot as when it had FI? (which I think is on the relay board in the engine compartment - is there both a fuse and relay? Which round relay is it? I have 4 and I don't know any of them - I've looked at the schematic and I'm still clueless)
Can I run a hotwire from the battery to the pump, bypassing the fuse/relay, to see if it cranks?
TIA.
robster.
I'd rather have a bottle-in-front-of-me than a frontal lobotomy.
Old 09-19-2003, 02:25 PM
