-   Porsche 914 & 914-6 Technical Forum (http://forums.pelicanparts.com/porsche-914-914-6-technical-forum/)
-   -   Spark Plugs for a stock 2.0 FI (http://forums.pelicanparts.com/porsche-914-914-6-technical-forum/128343-spark-plugs-stock-2-0-fi.html)
tod914 09-21-2003 07:19 AM
What plugs should I run and what gaps on a stock 2.0 FI.
Thanks,
Tod
pbanders 09-21-2003 07:30 AM
I use the factory-specified Bosch W7CC, the spec gap is 0.7 mm. I've used Bosch W7DTC's before, I thought they worked quite well - copper core with triple-electrode.
This page has all of the plug specs (as well as many other specs) for the 914. Note that most/all of the plug numbers are probably superceeded and will need to be checked against current reference guides.
http://www.porschedecals.com/history914wcodes.htm
SteveStromberg 09-21-2003 08:09 AM
When you need Wires we have the set that fit the 2.0. These are extra long with 4 98mm Connecters, they are $30.00 Steve
