mjbcf's Avatar
Porsche Crest 1974 914 2.0 Help
Car Still Fills With Gas I Change Temp Sensor 2 And Unplug The Cold Start Valve And Gas Line It Runs For About 10 Minintes And Floods Out Help Mike
Old 09-22-2003, 10:24 AM
hardflex's Avatar
Bad MPS diaphram? in effect, running injectors at full throttle.
72 914 2056: 74 9146 2.2: 76 914 2.0
Old 09-22-2003, 10:45 AM
hardflex's Avatar
-- Manifold Pressure sensor. you check it by pulling a vacuum on it. simple test would be to disconnect the hose at the air distributor and suck on it. If it's leaking any air past it's bad, and will send a signal to the brain box that means full load/throttle.
it's mounted passenger side on the body, below and behind the battery. It's about the size of your fist, and has a plug with 4 wires going in, and the hose to the airbox.
It's not uncommon for them to go bad after so many years.
Check it out.
The injection system
Old 09-22-2003, 07:27 PM
