Tidybuoy's Avatar
Question on Roling the Fender Lips
I just got a new 914 (did I mention that I won it in a raffle?)
Anyway, I discovered that my old 914 has the fender lips rolled to accomodate wider tires & the new car's fenders are completely stock.
How to you roll the fender lips without screwing it up or chipping any paint. My old 914 has it done perfectly but is was don by the prior owner.
Oh, here's a pic of the new car - 1974 2.0 with 5,000 on a rebuilt engine - for only $25 Yeah!
http://www.wvschools.com/tvhs/tvprint.htm
Vern
'06 Cayman S - Arctic Silver, "R" Springs & Struts, Spyder 19" Wheels, 82mm Plenum & Throttle Body.
'74 911 Coupe - Silber Metalic, PMO ITB, Electromotive Mgt
'16 BMW R Nine T (the fun one) & '17 BMW G310R
Old 09-26-2003, 10:27 AM
rolling fenders
many folks have used a wooden base ball bat: hold bat by handle and place it behind tire (toward the top) and have a friend SLOWLY drive vehicle forward.bat will be pushed up and around fender. you control (by the angle you are holding handle) the amount of width of fender and if done slowly with not too an extreme will minimize paint crackage.
Old 09-26-2003, 10:54 AM
If you do not need much, start with a broom handle. I have found that a piece of pvc pipe (I use 1-1/2") works better than a baseball bat. Load some weight into the trunk before you do it to compress the car down at the tires to get a better roll thru the whole suspension travel. I start the pipe up as previously described and just put the car in neutral and roll it back and forth keeping the pipe between the tire and body. It also helps to air up the tires so they will not give as much.
Old 09-26-2003, 11:13 AM
There is no chance you can do this with any guarantee of not messing up the paint. (I was surprised to learn there was filler in there when I went at it; needless to say filler is not too elastic.) If you are unwilling to paint, if necessary, then don't do it.
You may do it with no harm, but you can't bank on it
Old 09-26-2003, 11:29 AM
jkeyzer's Avatar
You won a 914 in a raffle?
Jeff Keyzer
72 914 w/2056 built by Mark DeBernardi @ Original Customs
Megasquirt with MSII upgrade
Old 09-26-2003, 12:13 PM
Tidybuoy's Avatar
Yep! I bought a $25 dollar raffle ticket. I still don't believe it! It looks pretty nice in the pics but I haven't seen it in person yet -
Vern
Old 09-26-2003, 01:36 PM
