LinkBack | Thread Tools | Rate Thread |
Extinguisher in hand
canna change law physics
Cracked injector?
James The pessimist complains about the wind; the optimist expects it to change; the engineer adjusts the sails.- William Arthur Ward (1921-1994) Red-beard for President, 2020 |
I will check them again. Maybe one of them could not handle the pressure. I did not look at the injectors because I thought a cracked one would leave fuel on top of the engine as well.
Administrator
Did you actually look under the car while the pump was running? That should tell you where the gas is coming from. Might be the pump body itself, even...
--DD
Pelican Parts 914 Tech Support A few pics of my car: http://www.pelicanparts.com/gallery/Dave_Darling |
I did. The gas seemed to be coming from up in the engine somewhere. It was just a stream from the push rod tube on the #3 cyl but no gas on top of the motor and the pump and hoses connected to it were dry as a bone.
Maybe the cold start valve?
'75 914-6 3.2 (Track Car) '81 SC 3.6 (Beast) '993 Cab (Almost Done Restoring) |
Thread Tools | |
Rate This Thread | |
