cassidy-online's Avatar
caliper conversion?
Hi,
Has anyone done the Porsche 914-4 to BMW caliper conversion? Dose is work well and is it as easy as they say?
Thanks, Chris.
Old 09-29-2003, 11:29 PM
John Rogers's Avatar
Yes, do a search of posts in this area and there are many posts to review.
Old 09-30-2003, 06:54 AM
skline's Avatar
I went one step past the BMW conversion. I went to the Volvo 240 brakes. They are 4 piston calipers and have twice the pad size as the 914. Ask Bernbomb about them. He is the one who told me about them. Work great. Here is a picture of mine after paint. BMW brakes will never look this good.
http://www.pelicanparts.com/gallery/skline
It's easier to get forgiveness than it is to get permission.
75 Slantnose V8
03 S-10 Extended cab stepside in Yellow
72 914 Parts car
Old 09-30-2003, 06:37 PM
Mike Corcoran's Avatar
Are they a direct bolt, and what year 240?
Old 10-01-2003, 07:42 AM
Never left, but not right
Zeke's Avatar
Where did you get the script?
Old 10-01-2003, 08:33 AM
chibone_914's Avatar
Hey!
Those look like mine... Did you remove the proportioning valve also?
Thank you!
John
johnechi@hotmail.com
Old 10-01-2003, 11:56 AM
yoh!!!'s Avatar
There is an other option...
BMW's 2002 have ATE brakes with four pistons, very similar to the Volvo conversion. Also with the same problems ...
You will need a bigger master brake cylinder (even 19mm is tight, 21mm might be good).
You will have to come up with some solution for the second brake line (that your 914 does not offer).
Patrick
'74 Porsche 914 2.0l
'90 VW Vanagon 1.7l Diesel
Old 10-01-2003, 12:09 PM
skline's Avatar
They are a direct bolt in(An upgrade for the BMW 320 racers) just use a spacer instead of machining metal off, the script I made in my garage on a machine I got for $40.00 at a garage sale and yes, you will need a larger master cylinder and I used VW brake T's for the rear proportioning valve and the 2 brake lines at each caliper. They have 2 different ones, the ones I am using are for vented rotors as I did the 911 front end onto the 914. I think these came from a mid 80's 240DL with vented front rotors.
75 Slantnose V8
72 914 Parts car
Old 10-01-2003, 04:58 PM
Yellowbird RS's Avatar
looking for more info about the volvo upgrade
X/A
Old 02-13-2006, 12:19 PM
