ruddyboys's Avatar
safety belt bolt location
Does anyone have a pic of the bottom bolt location where the passenger safety belt screws into. It seems that part of the car somehow dissapeared. I dont want to pull the driver side seatout and pull the carpet up to check.
74 LE "Bumblebee"
03 Jetta Wagon
Old 10-01-2003, 10:15 AM
jamcleod's Avatar
Send a message via AIM to jamcleod
??? errrrneaaah? the seat belt bolt goes into the vertical inner side, that is, if you grab the emergency brake handle with your left hand, the back of your hand is facing that vertical face. then the bolt it located next to your left hip. i think the "nut" thingy that the bolt screws into is welded in.
73 914 restoration project
73 914 2.0 CIS #80
74 914 1.8L L-jet
83 911SC
Old 10-01-2003, 11:14 AM
Here you go, the bottom two bolt locations on the passenger side.
Old 10-01-2003, 07:23 PM
Biggy72's Avatar
it's not that hard to pull the seat out, just take it out, or at least move it forward far enough to get to em.
Black 72 1.7 914
http://www.pelicanparts.com/gallery/Biggy72/
WSU Formula SAE
Drivetrain team leader/ Suspension team
http://www.mme.wsu.edu/~sae/
Old 10-01-2003, 08:49 PM
ruddyboys's Avatar
That perfect, thanks. Now it off to weld a new section.
74 LE "Bumblebee"
03 Jetta Wagon
Old 10-02-2003, 03:33 AM
