-   Porsche 914 & 914-6 Technical Forum (http://forums.pelicanparts.com/porsche-914-914-6-technical-forum/)
-   -   Sway bar question (http://forums.pelicanparts.com/porsche-914-914-6-technical-forum/130849-sway-bar-question.html)
cassidy-online 10-09-2003 06:14 AM
Sway bar question
Hi,
I bought a stock sway bar. Now the arms easily slides on and off of the torsion bar. What holds them on when they are installed in the car?
Also will the Weltmeister U-tab kit work with the stock sway bar?
And how well does the stock sway bar work?
Thanks, Chris.
skline 10-09-2003 06:47 AM
Get a bolt and a nut to go through it and tighten it up. They wont come off. As for the U tab, you could make your own. They came on the early cars and the S optioned cars. The Weltmiester fit would work also.
D7N7MASTER 10-09-2003 07:43 AM
I don't suppose you bought it on Ebay, did you?
sammyg2 10-09-2003 08:00 AM
If you tighten the clamp bolts all the way and they still are loose, your arms are worn out and wont work unless you have them welded, re-machined, or replaced. I would not try to weld then to the torsion bar.
maf 914 10-09-2003 08:27 AM
I don't have a stock type bar so I may not visualize this correctly, but, if the clamping bolt no longer tightens the arm to the bar couldn't you shim the arm-to-bar suface? This would then spread the split or clamping end of the arm and allow the clamping bolt to bite. Just an idea.
Mike
cassidy-online 10-09-2003 01:41 PM
reply
Yes, I bought it on ebay. I looked at the picture of " how to install a sway bar" and see that I am missing the bolts and the plates that clamp the arms to the bar. Hmmmm.
