cassidy-online's Avatar
Sway Bar Update
Now that I know how the arms clamp to the bar. What can I do if mine are missing the flat plates and bolts?. Are the plates just flat or do the fit into the arms at all? Also what size are the bolt?
Thanks, Chris.
It seems like the more I fix the more I take apart. Pretty soon there will be just a lot of parts where my car once was
Old 10-10-2003, 12:25 AM
Administrator
Send a message via AIM to Dave at Pelican Parts Send a message via Yahoo to Dave at Pelican Parts
I don't have mine handy, but I think I remember that the bolts are standard M8. The plates are simply flat--they help distribute the clamping load across the end of the arm.
Grab a spare M8 bolt (the ones that take a 13mm wrench) and see if it fits through. If it does with lots of slop, try to hunt up an M10 bolt (forget the wrench size for this). If it won't go at all, try an M6 bolt--10mm wrench size. Measure how long a bolt you need--don't forget to include the plates and washers, as well as having a little of the bolt sticking out the end of the nut!!
You can make the plates out of flat stock.
--DD
Old 10-10-2003, 07:29 AM
