D7N7MASTER's Avatar
Exclamation Where's My Instrument Lights?
Hi All,
We've had our '73 914, 2.0 since '99. Defenately a keeper. Fun car, minimum rust. Anyway, the instrument lights never did work from day one. Low priority in the list of what it would take to be able to drive it around the block - or to work after repairs & see if it leaks...
Well, the instrument lights still don't work. & NO it's not a fuse - or a tumor! I'm no electrician. What should I do???
www.pelicanparts.com/gallery/d7n7master
Old 10-10-2003, 06:42 PM
Administrator
Send a message via AIM to Dave at Pelican Parts Send a message via Yahoo to Dave at Pelican Parts
Check fuse #9 again. Twist the knob on the headlight switch to see if the dimmer is cranked down all the way.
--DD
Old 10-10-2003, 06:54 PM
D7N7MASTER's Avatar
I appreciate that Dave...Did I mention "since'99?" You know me; my credit card ends in xxxx. Oh my god, my c/c is burnin'!!! Seriously, I'm thinkin' about buying one of them there PP headlight switches. Or maybe a NOS fuse box. Or both. I don't know. Maybe I just bite the bullet & take it to an auto electric repair kinda place.
Old 10-10-2003, 07:06 PM
If the fuse is good, then a likely culprit is the rheostat that's burned out in the headlight switch. If you're lucky than a wire just came loose somewhere. If you pull out the switch so you can get a voltmeter on it you can find out if there's 12V getting to it, and if the rheostat is dropping the voltage fed to the lights. If you don't have a clue about basic electricity than maybe the repair shop is your best bet to getting it fixed. I suppose all the bulbs could be burned out but that seems unlikely.
Old 10-10-2003, 08:17 PM
D7N7MASTER's Avatar
Thanks. Can't I just install a new headlight switch?
Old 10-10-2003, 08:23 PM
skline's Avatar
If you want to, you can bring it by here tomorrow during the day and I will take a look at it for you. I used to work for Auto Electric in Fullerton. I may be able to find your problem and fix it for you. Give me a call tomorrow during the day. 714-318-3889
Scott
http://www.pelicanparts.com/gallery/skline
It's easier to get forgiveness than it is to get permission.
75 Slantnose V8
03 S-10 Extended cab stepside in Yellow
72 914 Parts car
Old 10-10-2003, 09:11 PM
