cary's Avatar
Exhaust Stud Torque ?
I'm putting a set of SS heat exchangers on my 2.0
One of the studs came out with the nut.
I used the torch to heat it up and got the nut off.
What is the correct torque to put the stud back in with ?
I used 12 ft lbs. It felt about right. But is the correct number ?
Went thru everything. Can't find the number listing anywhere.
Cary
77 Carrera RS w/3.2 #59
73 914S 2.0 AG
73 914 1.7 Driver ( daily driver, under complete rustoration )
74 914 2.0, 71 914 Tub, 74 914 2.0 Tub + 73 914 donor
Old 10-12-2003, 07:22 AM
chrisreale's Avatar
12 or 15 lbs. I think tight enough so there is no exhaust leaks is the "correct" number! Dont over tighten them, a busted stud can be a way to make you go prematurly bald.
1973 914 2.0 PCA Member GGRwww.pelicanparts.com/gallery/chrisreale/
www.914club.com
Old 10-12-2003, 02:37 PM
