race setup - total toe or toe per side?
dave darling's notes:
Sticky tires, 220# springs/21mm torsions/22mm front sway bar, track w/some autoX: -2.0 deg camber F -3.0 deg camber R ~1/16 inch toe-OUT front ~1/16 inch toe-IN rear Would that be 1/16" toe per side or 1/16" to total? Also, wouldn't 1/8" toe in at the rear be better for a racecar with the above specs? thanks, dr |
Total. Measuring the front toe per side is close to (but not completely) meaningless. For the rear, each side would get half that.
For a race car, though, you really need to get a pyrometer to be able to set the alignment and tire pressures accurately. The above are "general hints"--everyone's car and driving style is different, and you can get lower lap times by departing significantly from the suggestions above in some or many cases. --DD |
I recently took ulf to the track. My alignment specs are 1/16 toe, front and rear & -2 deg camber both ends.
At approx 100 mph the back end of the car started moving around...a bunch:eek: This was not under brakeing....straight line acceleration. I *suspect* it is a combination of rear lift and too little toe at that end. As the rear lifts, the toe decreases. Braking will also cause this....rear lift +braking forces pulling the toe out. Oddly enough, I didn't have braking stability problems when close to the *nasty* speed zone....that has me a bit confused. Needless to say, before I take the car to the track again, I'll be digging into the rear suspension. There may be something else going on there. As far as camber is concerned, it's a matter of what your tires like. Both Rspec Kumhos & Hoosiers like some negative camber. *On my car* -2 at the rear is too much. The insides of the tires are getting hotter than the outsides. The front seems to be spot on. |
This shows you why you really do need a pyrometer! The "general hints" are not correct in all cases! Frankly, they're probably wrong at least as often as they're right, in one particular or more.
If you're serious, get yourself a pyrometer and learn how to use it and interpret the readings! --DD |
thanks david,
I was just looking for a baseline setup. We have only run the car once since we finished the chassis. Will check the temps at the track this weekend. thanks, dr |
| All times are GMT -8. The time now is 11:46 AM. |
