Hi,
I've been lurking here for quite some time and I've used the information here for many of my problems. Just reciently, my car has started to pop out of first gear into neutral when I start moving. I can hold the stick back and forceably keep it in gear but this is not the answer. I've checked the engine mounts and they seem to be OK. The linkage is next. Is there anything else that I should be looking at or that does not seem obvious. Looks like a good weekend to work on the car! thanks, john
Es könnte schlimmer sein Everything is funny as long as it is happening to someone else. -Will Rogers |
adjust the linkage first!
76 914 2.0L Nepal Orange (2056 w/Djet FI, Raby Cam, 9to1 compression) www.914Club.com My Gallery Page |
canna change law physics
I know you don't want to hear this, but usually popping out of 1st and/or having trouble getting it into 1st gear are signs the slider and the dogteeth need replacing.
James
James The pessimist complains about the wind; the optimist expects it to change; the engineer adjusts the sails.- William Arthur Ward (1921-1994) Red-beard for President, 2020 |
