leaky head
This sounds lame to me. I'm putting the motor back together, stalled on the rocker geometry, and I noticed that theres a bit of oil dripping from where the cylinder hits the head. I lapped them, no gasket installed. And I'm sure no one uses any sealant between the two. What gives? will this tighten up and seal after the engine runs a while?
'75 1.8 -->1911 |
Hey, I had one of those, but the Doc gave me three shots of penecillin and it cured it.
Heat should cause it to tighten up (hopefully)
"Inventor - Blue Flame 914 Seat Heater" "Yellow Rusty Cars Are Faster" _____________________________ '70 2.5 (I'll never finish it - Somewhere over the rainbow.....,) '73 2.0 (Just Not The Same) '74 2.0 (Heartless & Lungless) |
Nothing worse than your Woodman getting a leaky head..............
'73 914 2.0 "Seriously Honey, the part was really really cheap...........honestly" |
C'mon guys...I'm getting flashbacks of jr. high now.
'75 1.8 -->1911 |
So, where's the oil source? I mean how much did you put in there during assembly? Many say put pistons in dry for immediate ring sealing.
BTW, one of the things I discovered when I burned up my motor was the heads were starting to leak. I now believe in Jake's stepping of the cyl tops to the special cut head. |
There was some oil in the cylinders and theres a tiny bit seeping between the cyl and the head.
What does the stepping mean?
'75 1.8 -->1911 |
