you guys are too funny....oh yeah, carbs vs EFI, LOL
Here's a dyno graph for a stock, rebuilt 2.0 with d-jet. I doubt that
carburetors can control the A/F ratio this well throughout the rev range. Click here to see picture |
If you decide to ditch the F.I. and go carbureted, use a single weber side draft DCOE and mount in on a garrett turbo. Hay, it worked for me ;)
Alfred, what does the squiggle at below 2800 mean? Is that normal?
Cams
Does someone have a Carb cam they'd like to reccomend...?
I' worked at a place where we commonly switched F/I busses to the 2 barrel Weber, and the 1.8 car I have now has 36 Dell's added with stock cam done at same place I believe. I remember even rebuilding a 2liter engine AS I WAS TOLD with some hi-perf cam and sticking the F/I back on! jeez...what a mess. Eventually went to Radio Shack and bought a resistor to run inline with the head-temp censor. Deliverance. I don't think I should ask around my town for what Cam to use... I'll probably run 40 DLRA's. Robert O 70' 914 |
Web-Cam 86--good all-around cam. There are some (like Jake Raby) who love split-duration cams, where the exhaust is open somewhat longer than the intake. Sounds like a reasonable idea to me, as the exhaust ports don't flow as well as the intakes on our motors. But those are, I think, more expensive than just the standard 86.
The 86a is, I believe, even more aggressive and loses more low RPM torque to pick up high RPM power. --DD |
FAT Performance FC442. .465lift 290deg duration. Much more sportee.
I'd allow lots of slop in choosing between cams - valve train geometry and setup makes a huge difference in realized lift, IIRC, depending how I did it, I'd get a .050" variance. I'd be real surprised if anyone gets full advertised lift out of most cams - if so it just goes to show that comparative claims at least should be taken with a grain of salt. I would view computer simulations based on those numbers as fun but rough guides as best. I played with every variable and maxed out at .438" IIRC with proper geometry, and was told I did well. It took longer than any other part of the rebuild. Dave |
| All times are GMT -8. The time now is 06:34 PM. |
