-   Porsche 914 & 914-6 Technical Forum (http://forums.pelicanparts.com/porsche-914-914-6-technical-forum/)
-   -   Weighed the beast - lead sled (http://forums.pelicanparts.com/porsche-914-914-6-technical-forum/135282-weighed-beast-lead-sled.html)
Buck toenges 11-11-2003 08:25 AM
It weighs in at 2,250 lbs with 1/2 tank of gas and without driver. What do you guys think? Chassis stiffener, Mayuer logitunal supports, 3.2, '88 911 front suspension, steel flares. Engine should put out about 230 hp at rear wheels.SmileWavy http://forums.pelicanparts.com/uploa...1068571499.jpg
Scooter311 11-11-2003 08:51 AM
Nice, really sharp looker - and it performs too? What more can anyone ask for?
I like the color/wheels/side stripe and trim too.
I can't tell from the picture, what type of spoiler do you have on the front?
Cheers!
Jeff
synthesis 11-11-2003 08:52 AM
I am at 1908 with 1/2 fuel, no driver. Car has full 8pt cage and fuel cel but 4cyl motor.
At 2250, your car is about what I would expect with full interior and the 6cyl.
There are lots of ways to lose weight on your car but that = $.
regards,
dr
Joe Bob 11-11-2003 01:28 PM
Take out the stereo, the boom tube, all the insulation, go with fiberglass everything......%^B
kellzey 11-11-2003 01:33 PM
Things you can do to reduce weight and not affect appearance...
Fiberglass front and rear hood from Getty Design... (A nice GT copy). (Proably about 30-40 lbs)
Tar on the floors, the rubber mat behind the backpad and the firewall pad (I assume this is gone). About 20 lbs or more
Also consider...
Fiberglass front and rear bumpers (would be black instead of chrome), but would save another 30-40 lbs.
I'm doing all the above, but without the longitudinal stiffeners, so I should be under 2200 lbs.
John 9:14 11-11-2003 01:38 PM
Sweeeeet.....I almost popped a chub lookin at that. Does anyone make glass doors for 914s?
sean_V8_914 11-11-2003 02:51 PM
it would look better if it was in my garage
M. Hendrix 11-11-2003 02:55 PM
You can build a complete 914 out of tubes, and glass, everything is available.
M
sammyg2 11-11-2003 03:02 PM
Can I have? Please?
D7N7MASTER 11-11-2003 04:52 PM
...then I woke up.
DonNewton 11-11-2003 06:28 PM
Ha! I just stole the z-man's avatar. . .Now, it resides in a file with bouncy!
